من یه دماسنج با smt160 ساختم ولی دما ثابت نیست و چند درجه پرش داره
میشه راهنمایی کنید
اینم برنامه
#include <mega16.h>
#include <delay.h>
#include <stdio.h>
#include <stdlib.h>
#include <lcd.h>
#asm
.equ __lcd_port=0x1B;
#endasm
bit control=0;
float temp;
float DC;
float T1 , T2;
char str[20];
interrupt [EXT_INT0] void ext_int0_isr(void)
TCCR1B=0x00;
if (control)
T2=TCNT1;
TCNT1=0;
MCUCR=0x02;
control=0;
else{
T1=TCNT1;
TCNT1=0;
MCUCR=0x03;
control=1;
TCCR1B=0x02;
void main(void)
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Clock value: 1000.000 kHz
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Timer1 Overflow Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x02;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: On
// INT0 Mode: Falling Edge
// INT1: Off
// INT2: Off
GICR|=0x40;
MCUCR=0x02;
MCUCSR=0x00;
GIFR=0x40;
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Global enable interrupts
#asm("sei"
lcd_init(16);
while (1)
DC=T1/(T1+T2);
DC+=0.018;
temp=(DC-0.32)/0.0047;
lcd_clear();
lcd_gotoxy(0,0);
sprintf(str,"temp:%f\XDFC",temp);
lcd_puts(str);
delay_ms(400);
میشه راهنمایی کنید
اینم برنامه
#include <mega16.h>
#include <delay.h>
#include <stdio.h>
#include <stdlib.h>
#include <lcd.h>
#asm
#endasm
bit control=0;
float temp;
float DC;
float T1 , T2;
char str[20];
TCCR1B=0x00;
if (control)
T2=TCNT1;
TCNT1=0;
MCUCR=0x02;
control=0;
else{
T1=TCNT1;
TCNT1=0;
MCUCR=0x03;
control=1;
TCCR1B=0x02;
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x02;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: On
// INT1: Off
// INT2: Off
GICR|=0x40;
MCUCR=0x02;
MCUCSR=0x00;
GIFR=0x40;
TIMSK=0x00;
// USART disabled
UCSRB=0x00;
ACSR=0x80;
SFIOR=0x00;
// ADC disabled
ADCSRA=0x00;
// SPI disabled
SPCR=0x00;
// TWI disabled
TWCR=0x00;
#asm("sei"
lcd_init(16);
while (1)
DC=T1/(T1+T2);
DC+=0.018;
lcd_clear();
lcd_gotoxy(0,0);
lcd_puts(str);
delay_ms(400);
