پاسخ : اتباط ٢ میکرو با i2c
برنامه اسلیو
#include <mega8.h>
#include <delay.h>
// I2C Bus functions
#asm
.equ __i2c_port=0x15 ;PORTC
.equ __sda_bit=0
.equ __scl_bit=1
#endasm
#include <i2c.h>
char myi2c_read(unsigned char bus_adrs)
char myi2c;
i2c_start();
i2c_write(bus_adrs);
i2c_start();
i2c_write(bus_adrs | 1);
myi2c=i2c_read(0);
i2c_stop();
PORTB.0=0x01;
if(myi2c==0x77)PORTB.1=0x01;
return myi2c;
char tt;
void main(void)
// Port B initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
// Port D initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Clock value: Timer1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Timer1 Overflow Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// I2C Bus initialization
//______________________________khodam ezafe kardam
//-------------- Initial Setting ---------------
TWAR = 0x01; // Slave Address
TWBR=0x05; // Bit Rate: 38.462 kHz
TWCR = 0xC4; // Clear Int, Set TWEA and TWEN
i2c_init();
while(1){
tt=myi2c_read(0x01);
if(tt==0x77)PORTB.2=0x01;
else
PORTB.2=0x00;
برنامه اسلیو
#include <mega8.h>
#include <delay.h>
#asm
.equ __sda_bit=0
.equ __scl_bit=1
#endasm
#include <i2c.h>
char myi2c;
i2c_start();
i2c_start();
myi2c=i2c_read(0);
i2c_stop();
PORTB.0=0x01;
return myi2c;
char tt;
void main(void)
PORTB=0x00;
DDRB=0xFF;
PORTD=0x00;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x00;
ACSR=0x80;
SFIOR=0x00;
i2c_init();
while(1){
else
PORTB.2=0x00;
