دوستان میخاستم موتوره براشلسو با میکرو راه اندازی کنم ولی هر کاری میکنم روشن نمیشه.
کسی میتونه کمکی کنه؟
[LEFT] $regfile "m64def.dat" $crystal = 16000000 '$hwstack = 64 'default use 32 for the hardware stack '$swstack = 64 'default use 10 for the SW stack '$framesize = 64 'default use 40 for the frame space '$baud = 9600 Config Timer1 = Timer , Prescale = 64 '-------------- Config Timer1 = Pwm , Prescale = 64 , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down '------------ 16 Mhz / 64 = 250 Khz = 4 uS '---------- 4 uS x 31,250 = 125,000 uS = 0.125 S '---------- Multiply with 8 = 1 S Config Timer3 = Pwm , Pwm = 8 , Compare A Pwm = Clear up , Compare B Pwm = Clear up , Prescale = 64 Config Pine.3 = Output 'pwm3a-left Config Pine.4 = Output 'Pwm3b-left Config Portf = Output Config Portc = Output Config Portd = Input Config Pine.5 = Input 'kelid-int5 Config Pine.6 = Input 'kelid-int6 Config Pine.7 = Input 'kelid-int7 Dim Rpm As Word Dim Multiplier As Byte Hijau Alias Pine.5 Biru Alias Pine.6 Kuning Alias Pine.7 Portd = &HFF Step1 Alias &B00100001 Step2 Alias &B00001001 Step3 Alias &B00011000 Step4 Alias &B00010010 Step5 Alias &B00000110 Step6 Alias &B00100100 Timer1 = 34286 Multiplier = 0 Timer0 = 0 Tccr0 = 6 Do while Pine.6 = 1 ' Gosub Komutator Enable Timer1 On Timer1 Multiply Enable Interrupts print rpm Wend Loop End Komutator: If Hijau = 0 And Biru = 0 And Kuning = 1 Then Portf = Step1 Portc.0 = 0 Portc.2 = 0 Portc.4 = 1 If Hijau = 0 And Biru = 1 And Kuning = 1 Then Portf = Step2 Portc.0 = 0 Portc.2 = 1 Portc.4 = 1 If Hijau = 0 And Biru = 1 And Kuning = 0 Then Portf = Step3 Portc.0 = 0 Portc.2 = 1 Portc.4 = 0 If Hijau = 1 And Biru = 1 And Kuning = 0 Then Portf = Step4 Portc.0 = 1 Portc.2 = 1 Portc.4 = 0 If Hijau = 1 And Biru = 0 And Kuning = 0 Then Portf = Step5 Portc.0 = 1 Portc.2 = 0 Portc.4 = 0 If Hijau = 1 And Biru = 0 And Kuning = 1 Then Portf = Step6 Portc.0 = 1 Portc.2 = 0 Portc.4 = 1 Return Multiply: Timer1 = 34286 incr Multiplier If Multiplier = 8 Then Multiplier = 0 Rpm = Timer0 * 15 'Here is the RPM Value Timer0 = 0 End If Return [/LEFT]
