smart card programmer
    نقشه کامل مدارش لطفا smart card programmer
    Re: smart card programmer
    نوشته اصلی توسط siolishe
    "SimpleMouse" Smartcardprogrammer
    source: Keule
    This "SimpleMouse" Smartcardprogrammer can be used to read and write most of all async - Smartcards (Processorcards), including the new "Hornet and +1" DPSC΄s in update and reprogramming mode.
    It is jumper-selectable in either Smartmouse or Phoenix Mode (Reset active hi or low) and Jumper selectable for 3.57 and 6 MHz
    The "original" Smartmouse gets its power out of the serial port of the Hostcomputer - in this design this "feature" is not implemented because the Hostcomputer can only deliver about 15 mA to the Programmer. This is not enough for older Smartcards. So this design uses an 9V Alkaline Battery 6LR61.
    To make this design cheap there are no gimmicks like flashing diodes or expensive connectors and switches. You have to solder the 9 or 25 pin serial cable directly the corresponding pads of the PCB.
    There is an new/other Layout included. It has some 100R Resistors in
    the connections to the smartcard, to limit the current in the case
    of malfunction of the software. Furthermore the Layout is a litte more
    easier to build at home because the distance between the tracks is
    bigger....
    All the following description is also usable for the new layout. Some
    changes in the partvalues have to be taken directly out of the Top1.gif.
    The LEDs schould be LowPower....
    Download the files in zip
    http://www.electronics-lab.com/projects/mcu/002/003.zip
    JUMPERS
    SIP1 is for selecting the Clockrate 3.57 or 6MHz
    SIP 1
    Shorting pin 1 + 2 -> 3.57 MHz
    Shorting pin 2 + 3 -> 6 MHz
    SIP2 is for selecting the type of mode (Smartmouse or Phoenix)
    SIP 2
    Shorting pin 1 + 2 -> Smartmouse
    Shorting pin 2 + 3 -> Phoenix
    SIP3
    SIP3 is a Jumperblock which is used as a "Switch" to turn the Battery
    on an off - or as the connector for an external DC-powersupply.
    Shorting pin 1+2 -> Power off
    Shorting pin 2+3 -> Power on
    Without Jumper you can connect an external DC-Powersupply to this Header:
    Pin1 -> GND
    Pin2 -> 9 to 15 Vdc
    Pin3 -> left open
    SIP4
    SIP3 is΄nt really a Jumperblock it is the connection to the serial
    Port of the Hostcomputer.
    SIP4 9Pin SubD Serial port cable
    Pin1 -> Pin 5
    Pin2 -> Pin 2
    Pin3 -> Pin 3
    Pin4 -> Pin 1
    Pin5 -> Pin 7
    PART LIST
    ID Comment
    BT1 9V Block Alkaline
    C1 22pF RM 5 Keramik
    C2 22pF RM 5 Keramik
    C3 22pF RM 5 Keramik
    C4 22pF RM 5 Keramik
    C5 100nF RM 5 KDPU
    C6 100nF RM 5 KDPU
    C7 1uF RM 2.5 Tantal
    C8 1uF RM 2.5 Tantal
    C9 1uF RM 2.5 Tantal
    C10 1uF RM 2.5 Tantal
    C11 1u RM 2.5 Tantal
    C12 100nF RM 5 KDPU
    C13 100nF RM 5 KDPU
    C14 47pF RM 5 Keramik
    C15 1uF RM 2.5 Tantal
    D1 BAT41 or BAT48 Shottky!!
    D2 1N4148
    LD1 LED 3mm red Low Power
    R1 1M RM 5 Bauform 02/04 1/10W
    R2 2K2 RM 5 Bauform 02/04 1/10W
    R3 1M RM 5 Bauform 02/04 1/10W
    R4 2K2 RM 5 Bauform 02/04 1/10W
    R5 2K2 RM 5 Bauform 02/04 1/10W
    R6 2K2 RM 5 Bauform 02/04 1/10W
    R7 10K RM 5 Bauform 02/04 1/10W
    SC1 Smartcard Adapter Amphenol Switch opens when Card is inserted!
    SIP1 Jumperblock 3Pin
    SIP2 Jumperblock 3Pin
    SIP3 Jumperblock 3Pin
    SIP4 Jumperblock 5Pin
    U1 74HC00
    U2 MAX 232
    U3 78L05
    X1 3.57MHz HC18/U
    X2 6MHz HC18/U
    All Rs are 1/10W 4mm for laying mount or 1/4 W for standing mount.
    REMARKS
    It is very important for this design to use a Shottky diode for D1.
    Any other type will definitely NOT work!
    Look for the right polarity of the tantalum condensators! The
    MAX232 includes a so called chargepump and generates positive an
    negative Voltages respect to ground. So it is possible that the
    positive pole of an condensator is connected to ground - this is
    NOT wrong!
    For Mounting the Battery and fasten the serial cabel drill bigger
    holes at the corresponding points and use cablestrips.
    The enclosed Tiff΄s have a resolution of 400 dpi.
    Das Layout5 ist um folgende Bauteile erweitert
    IC NE555
    R 10K
    R 120K
    C 1uF Elko
    Taster 1 x UM
    Der Taster muss in Ruhestellung Masse Stromversorgung mit Masse Board verbinden, gedrόckter Position PIN3 NE555 MIT Masse Board.
    Durch diese einfache Erweiterung kφnnen Karten genullt bzw. reanimiert werden ohne das raus-rein Spiel, welches die Karte unnόtz strapaziert.
    Greetz Keule-
    {خلاف قوانین - پاک شد }
      مرسی ولی با عرض تاسف اینو خودم داشتم!
      من یه چیز جامع تر میخوام
      خواهشا بهم کمک کنین! :(
        سلام من خیلی وقت دنبال SMARTcard هستم میشه بگید از کدوم فروشگاه میتونم پیدا کنم؟
        منظورم خود کارتش ها . :arrow:
        11001010110010001100100011110010101111101100101
        011000110110110001100101011000110111010001101001
        01100011
          نقشه مدار کابل upgraed دستگاه spark 2000 plus 2m (rs-232c)
            gold card programmer
            عزیزان لطفا اگر مدار gold card programmer دارید که تست کرده و جواب گرفته اید را بگذارید.تشکر
