آقا من این برنامه را توی modelsim pe v10 نوشتم - این 3 تا پیغام خطا را نمیده ؟ هرکاری میکنم بازم همینا رو میگه - اگه کسی وارده خواهش می کنم کمک کنه - برنامه یه ضرب کننده هست -
اینم error هاشه :
مرسی
------ and_2.vhd (component): ---------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY and_2 IS
PORT ( a, b: IN STD_LOGIC;
y: OUT STD_LOGIC);
END and_2;
ARCHITECTURE and_2 OF and_2 IS
BEGIN
y <= a AND b;
END and_2;
------ reg.vhd (component): -----------
LIBRARY ieee;
ENTITY reg IS
PORT ( d, clk, rst: IN STD_LOGIC;
q: OUT STD_LOGIC);
END reg;
ARCHITECTURE reg OF reg IS
BEGIN
PROCESS (clk, rst)
BEGIN
IF (rst='1'
THEN q<='0';
ELSIF (clk'EVENT AND clk='1'
THEN q<=d;
END IF;
END PROCESS;
END reg;
------ fau.vhd (component): -----------
LIBRARY ieee;
ENTITY fau IS
PORT ( a, b, cin: IN STD_LOGIC;
s, cout: OUT STD_LOGIC);
END fau;
ARCHITECTURE fau OF fau IS
BEGIN
s <= a XOR b XOR cin;
cout <= (a AND b) OR (a AND cin) OR (b AND cin);
END fau;
------ pipe.vhd (component): ----------
LIBRARY ieee;
USE work.my_components.all;
ENTITY pipe IS
PORT ( a, b, clk, rst: IN STD_LOGIC;
q: OUT STD_LOGIC);
END pipe;
ARCHITECTURE structural OF pipe IS
SIGNAL s, cin, cout: STD_LOGIC;
BEGIN
U1: COMPONENT fau PORT MAP (a, b, cin, s, cout);
U2: COMPONENT reg PORT MAP (cout, clk, rst, cin);
U3: COMPONENT reg PORT MAP (s, clk, rst, q);
END structural;
----- my_components.vhd (package):-----
LIBRARY ieee;
PACKAGE my_components IS
COMPONENT and_2 IS
PORT (a, b: IN STD_LOGIC; y: OUT STD_LOGIC);
END COMPONENT;
COMPONENT fau IS
PORT (a, b, cin: IN STD_LOGIC; s, cout: OUT STD_LOGIC);
END COMPONENT;
COMPONENT reg IS
PORT (d, clk, rst: IN STD_LOGIC; q: OUT STD_LOGIC);
END COMPONENT;
COMPONENT pipe IS
PORT (a, b, clk, rst: IN STD_LOGIC; q: OUT STD_LOGIC);
END COMPONENT;
END my_components;
----- multiplier.vhd (project): -------
LIBRARY ieee;
ENTITY multiplier IS
PORT ( a, clk, rst: IN STD_LOGIC;
b: IN STD_LOGIC_VECTOR (3 DOWNTO 0);
prod: OUT STD_LOGIC);
END multiplier;
ARCHITECTURE structural OF multiplier IS
SIGNAL and_out, reg_out: STD_LOGIC_VECTOR (3 DOWNTO 0);
BEGIN
U1: COMPONENT and_2 PORT MAP (a, b(3), and_out(3));
U2: COMPONENT and_2 PORT MAP (a, b(2), and_out(2));
U3: COMPONENT and_2 PORT MAP (a, b(1), and_out(1));
U4: COMPONENT and_2 PORT MAP (a, b(0), and_out(0));
U5: COMPONENT reg PORT MAP (and_out(3), clk, rst,
reg_out(3));
U6: COMPONENT pipe PORT MAP (and_out(2), reg_out(3),
clk, rst, reg_out(2));
U7: COMPONENT pipe PORT MAP (and_out(1), reg_out(2),
clk, rst, reg_out(1));
U8: COMPONENT pipe PORT MAP (and_out(0), reg_out(1),
clk, rst, reg_out(0));
prod <= reg_out(0);
END structural;
LIBRARY ieee;
ENTITY and_2 IS
y: OUT STD_LOGIC);
END and_2;
BEGIN
y <= a AND b;
END and_2;
LIBRARY ieee;
ENTITY reg IS
q: OUT STD_LOGIC);
END reg;
BEGIN
PROCESS (clk, rst)
BEGIN
IF (rst='1'
END IF;
END PROCESS;
END reg;
LIBRARY ieee;
ENTITY fau IS
END fau;
BEGIN
END fau;
LIBRARY ieee;
ENTITY pipe IS
q: OUT STD_LOGIC);
END pipe;
BEGIN
END structural;
LIBRARY ieee;
COMPONENT and_2 IS
END COMPONENT;
COMPONENT fau IS
END COMPONENT;
COMPONENT reg IS
END COMPONENT;
COMPONENT pipe IS
END COMPONENT;
END my_components;
LIBRARY ieee;
END multiplier;
BEGIN
reg_out(3));
prod <= reg_out(0);
END structural;
اینم error هاشه :
** Error: (vcom-11) Could not find work.my_components.
** Error: C:/----------------/new 1.vhd(52): (vcom-1195) Cannot find expanded name "work.my_components".
** Error: C:/-----------------------/new 1.vhd(52): Unknown expanded name.
** Error: C:/---------------------------i/new 1.vhd(54): VHDL Compiler exiting
مرسی
