من خیلی وقت نیست که vhdl رو شروع کردم. یه برنامه کوچیکی هم نوشتم که یه ارور داره و متاسفانه نتونستم ازش سر در بیارم و سرچ کردن هم کار ساز نشد
ارور: Line 70: statement is not synthesizable since it does not hold its value under NOT(clock-edge) condition
ارور مربوط میشه به خط IF RISING_EDGE(IR_IN) THEN
مرسی
---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 20:31:38 02/24/2015 -- Design Name: -- Module Name: main - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity main is Port ( GCLK : in STD_LOGIC; IR_IN: in STD_LOGIC; LED_1 : out STD_LOGIC; LED_2 : out STD_LOGIC; LED_3 : out STD_LOGIC; LED_4 : out STD_LOGIC); end main; architecture Behavioral of main is SIGNAL Ctr: STD_LOGIC_VECTOR ( 23 DOWNTO 0); SIGNAL state : STD_LOGIC:= '0'; begin LED_1 <= '0'; LED_3 <= '0'; PROCESS (GCLK) BEGIN IF FALLING_EDGE(GCLK) THEN IF Ctr = X"FFFFF7" THEN Ctr <= (OTHERS => '0'); IF state = '0' THEN state <= '1'; LED_4 <= '1'; ELSE state <= '0'; LED_4 <= '0'; END IF; ELSE Ctr <= Ctr + X"1"; END IF; END IF; END PROCESS; PROCESS (IR_IN) BEGIN IF RISING_EDGE(IR_IN) THEN LED_2 <= '0'; ELSIF FALLING_EDGE(IR_IN) THEN LED_2 <= '1'; END IF; END PROCESS; end Behavioral;
مرسی
