RTC با DS1307 و ATmega16
    salam.....
    projeye fareghotahsilim sakhte ye CALLER ID ke ye seri emkanate dige be joz namayeshe shomare telephon bayad dashte bashe ke yekish namayeshe zamane...
    ba inke madaram to proteus kamelan dorost javab mide,nemidoonam ke chera sakhtafzaram javab nemide....
    kasayee ke az in madar javab gereftan,khahesh mikonam rahnamayeem konan....
    TNX...
    Chip type      : ATmega16
    Program type    : Application
    Clock frequency   : 8.000000 MHz
    Memory model    : Small
    External SRAM size : 0
    Data Stack size   : 256
    #include <mega16.h>
    #include <delay.h>
    #include<stdio.h>
    // I2C Bus functions
    #asm
      .equ __i2c_port=0x1B ;PORTA
      .equ __sda_bit=0
      .equ __scl_bit=1
    #endasm
    #include <i2c.h>
    // DS1307 Real Time Clock functions
    #include <ds1307.h>
    // Alphanumeric LCD Module functions
    #asm
      .equ __lcd_port=0x18 ;PORTB
    #endasm
    #include <lcd.h>
    unsigned char hour,minute,second;
    char lcd1[16],lcd2[16];
    unsigned char year,month,day;
    unsigned char key,keystate;
    struct days{ char d[4];} daysofweek[7]={{"Sun"},{"Mon"},{"Tue"},{"Wed"},{"Thu"},{"Fri"},{"Sat"}};
    flash unsigned char Table[13]={0,0,3,3,6,1,4,6,2,5,0,3,5};
    flash unsigned char miltable[6][12]={
        {20,19,19,19,20,20,21,21,21,21,20,20},
        {10,11,10,12,11,11,10,10,10,9,10,10},
        {19,18,20,20,21,21,22,22,22,22,21,21},
        {11,12,10,11,10,10,9,9,9,8,9,9},
        {20,19,20,20,21,21,22,22,22,22,21,21},
        {10,11,9,11,10,10,9,9,9,8,9,9}};
     struct date{
     unsigned char day;
     unsigned char month;
     unsigned char year;
     struct date shmdate,mildate ;
    void miltoshmcv(unsigned char ym,unsigned char mm,unsigned char dm)
      unsigned char k,t1,t2;
      k=ym%4;
      if(k==3)
        k=2;
      k*=2;
      t1=miltable[k][mm-1];
      t2=miltable[k+1][mm-1];
      if(mm<3 || (mm==3 && dm<=miltable[k][mm-1]))
        shmdate.year = ym + 78;
      else
        shmdate.year = ym + 79;
      if(dm<=t1)
        shmdate.day=dm+t2;
        shmdate.month=(mm+8)%12+1;
      else
        shmdate.day=dm-t1;
        shmdate.month=(mm+9)%12+1;
    char IsLeapYear(int Year)
      Year=Year&0x0003;
      if(Year==0)
       return 1;
      else
       return 0;
    char GetDayofWeek(unsigned char CurrentYear,unsigned char Month,unsigned char Day)
      unsigned int TempYear;
      unsigned char AccValue;
      TempYear = 1990;/*Comparation start with year 1990*/
      AccValue = 0;/*Init AccValue to 0*/
      /* If TempYear is a leap year AccValue +2, else AccValue+1 */
      while(TempYear != (CurrentYear+2000))
       AccValue++;
       if(IsLeapYear(TempYear))
        AccValue++;
       TempYear++;
      if(Month > 2)
       if(IsLeapYear(TempYear)==1)
       AccValue++;
      AccValue += Table[Month];
      AccValue += Day;
      AccValue= AccValue%7;
      return (AccValue);
    void main(void)
    // Port A initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTA=0x00;
    DDRA=0x00;
    // Port B initialization
    PORTB=0x00;
    DDRB=0x00;
    // Port C initialization
    PORTC=0x00;
    DDRC=0x00;
    // Port D initialization
    PORTD=0xFF;
    DDRD=0x00;
    // Clock source: System Clock
    // Clock value: Timer 0 Stopped
    // Mode: Normal top=FFh
    // OC0 output: Disconnected
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    // Clock value: Timer 1 Stopped
    // Mode: Normal top=FFFFh
    // OC1A output: Discon.
    // OC1B output: Discon.
    // Noise Canceler: Off
    TCCR1A=0x00;
    TCCR1B=0x00;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    // Clock value: Timer 2 Stopped
    // OC2 output: Disconnected
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    TIMSK=0x00;
    // Analog Comparator: Off
    ACSR=0x80;
    SFIOR=0x00;
    // I2C Bus initialization
    i2c_init();
    // DS1307 Real Time Clock initialization
    // Square wave output on pin SQW/OUT: Off
    // SQW/OUT pin state: 0
    rtc_init(0,0,0);
    // LCD module initialization
    lcd_init(16);
    while (1)
      rtc_get_time(&hour,&minute,&second);
      rtc_get_date(&day,&month,&year);
      miltoshmcv(year,month,day);
    key=PIND & 0b11111100;
    if (key!=keystate)
      if (key!=0b11111100)
        if (key==0xF8)    //if key 1 pressed set the year
          year++;
          if (year==100)
            year=0;
        if (key==0xF4)    //if key 2 pressed set the month
          month++;
          if (month==13)
            month=1;
        if (key==0xEC)    //if key 3 pressed set the day
          day++;
          if (day==32)
            day=1;
        if (key==0xDC)    //if key 4 pressed set the hour
          hour++;
          if (hour==24)
            hour=0;
        if (key==0xBC)    //if key 5 pressed set the minute
          minute++;
          if (minute==60)
            minute=0;
        if (key==0x7C)    //if key 6 pressed set the second
          second++;
          if (second==60)
            second=0;
        rtc_set_time(hour,minute,second);
        rtc_set_date(day,month,year);
        keystate=key;
      }else
        keystate=0b11111100;
      //sprintf(lcd1,"%02u:%02u:%02u",hour,minute,second,);
      //sprintf(lcd2,"%02u/%02u/%02u",shmdate.year,shmdate.month,shmdate.day);
      sprintf(lcd1,"%02u/%02u/%02u ",shmdate.year,shmdate.month,shmdate.day);
      sprintf(lcd2,"%s %02u:%02u:%02u",daysofweek[GetDayofWeek(year,month,day)].d,hour,minute,second);
      lcd_clear();
      lcd_gotoxy(0,0);
      lcd_puts(lcd1);
      lcd_gotoxy(0,1);
      lcd_puts(lcd2);
      delay_ms(100);
    [img][/img]
    پاسخ : RTC با DS1307 و ATmega16
    اول اینکه لطفا به قوانین احترام بگذارید و فارسی تایپ کنید
    دوم اینکه من سی بلد نیستم ولی اگه تئو پروتئوس جواب میده پس برنامه تون مشکل نداره
    فقط DS1307 چند نکته داره که تو پروتئوس رعایت نمیشه
    1- ساعت رو حتما باید اول تنظیم کنید و تا به ثانیه مقدار اولیه ندید شروع به کار نمیکنه
    2- باطری برای این آی سی خیلی مهمه پس حتما باطری بذارید در غیر اینصورت حتما حتما پایه باطری را زمین کنید
    3- از مقاومت پول پ داخلی میکرو نمیشه استفاده کرد و حتما باید مقاومتها خارجی باشند
      من برای این ایسی میخام باطری بک پ بزارم
      ولی نمی دونم که مدار شارژش باطری بک پ چی بزارم
      اگه چیزی میدونید ممنون میشم منو هم بی بهره نذارید :bye
        شارژر چی کشک چی دوغ چی؟؟؟؟؟؟؟؟؟؟؟؟
        شارژ میخوای چیکار؟
        این آی سی آنقدر کم مصرفه که طبق گفته خود دیتاشیت با یک باطری مخصوص بک پ(از همونایی که روی مین بورد کامپیوترها هست و تو بازار به وفور یافت میشه) بیشتر از ده سال کار میکنه !!!!!!!!!!!!
        این حرف اغراق هم نیست چون من خودم با یک باطری تا حالا که از ساخت مدارم حدود سه سال میگذره مشکلی نداشتم و جریانش افت نکرده
        ولی اگر اسرار دارید که از شارژر استفاده کنید یه آیی سی ساعت هست (فکر کنم شمارش DS1340 بود) که خودش شارژر داخلی داره
          من برای پروژه ام میخام
          دو سه روز کار کنه حله !
          امیدوارم کردی مرسی
          راستی باطری همون گرد ها رو میگی ؟
          اونا قاب مخصوص برای خودشون دارن ؟
          این ایسی چه ولتی میخاد ؟
            سه روز که هیچی سه هزار روز هم برات کار میکنه
            بله همون گردها
            اینجا تو شهر ما بهش میگن باطری دکمه ای اونجا رو نمیدونم (به باطری بک پ هم مشهوره)
            بله جا باطریش هم هست
            این باطریها سه ولته و کاملا مناسبds1307 (برای همین کار ساخته شده)
            ولتاژ تغذیه خود این ای سی هم 5 ولته ولی تغذیه بک پ که قرار شد از این باطری استفاده کنید همین 3 ولت کاملا مناسبه
              دوستان منم این مشکل رو دارم . کد من فقط عدد 165 رو (چه برای ثانیه چه دقیقه و ساعت ) نشون میده
              This program was produced by the
              CodeWizardAVR V1.24.4 Standard
              Automatic Program Generator
              © Copyright 1998-2004 Pavel Haiduc, HP InfoTech s.r.l.
              http://www.hpinfotech.com
              e-mail:office@hpinfotech.com
              Project :
              Version :
              Date  : 05/04/2010
              Author : KOrosh
              Company : Korosh
              Comments:
              Chip type      : ATmega16L
              Clock frequency   : 8,000000 MHz
              #include <mega16.h>
              #include <stdlib.h>
              #include <delay.h>
              #asm
                .equ __sda_bit=0
                .equ __scl_bit=1
              #endasm
              #include <i2c.h>
              #include <ds1307.h>
              #asm
              #endasm
              #include <lcd.h>
              void main(void)
                  unsigned char h,m,s;
                  unsigned char sc[20];
              PORTA=0x00;
              DDRA=0x00;
              PORTB=0x00;
              DDRB=0x00;
              PORTC=0x00;
              DDRC=0x00;
              PORTD=0x00;
              DDRD=0x00;
              TCCR0=0x00;
              TCNT0=0x00;
              OCR0=0x00;
              TCCR1A=0x00;
              TCCR1B=0x00;
              TCNT1H=0x00;
              TCNT1L=0x00;
              ICR1H=0x00;
              ICR1L=0x00;
              OCR1AH=0x00;
              OCR1AL=0x00;
              OCR1BH=0x00;
              OCR1BL=0x00;
              ASSR=0x00;
              TCCR2=0x00;
              TCNT2=0x00;
              OCR2=0x00;
              // INT0: Off
              // INT1: Off
              // INT2: Off
              MCUCR=0x00;
              MCUCSR=0x00;
              TIMSK=0x00;
              ACSR=0x80;
              SFIOR=0x00;
              i2c_init();
              // SQW/OUT pin state: 1
              rtc_init(0,0,1);
              lcd_init(16);
              lcd_clear();
              lcd_gotoxy(0,0);
              //rtc_set_time(1,2,3);
              delay_ms(1000);
              while (1)
                  rtc_get_time(&h,&m,&s);
                  itoa(s,sc);
                  lcd_gotoxy(0,0);
                  lcd_puts(sc);
                  delay_ms(50);
