#include <delay.h>
#include <Stdlib.h>
#include <mega16.h>
// Alphanumeric LCD Module functions
#asm
.equ __lcd_port=0x15
#endasm
#include <lcd.h>
char st[10];
int i=0,a,b,c,d,k,l,m,e;
eeprom int j=3211 ;
void main(void)
// Port A initialization
// Func0=In Func1=In Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In
// State0=T State1=T State2=T State3=T State4=T State5=T State6=T State7=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func0=Out Func1=Out Func2=Out Func3=Out Func4=Out Func5=Out Func6=Out Func7=Out
// State0=0 State1=0 State2=0 State3=0 State4=0 State5=0 State6=0 State7=0
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
// Func0=In Func1=In Func2=In Func3=In Func4=Out Func5=Out Func6=In Func7=In
// State0=T State1=T State2=T State3=T State4=0 State5=0 State6=T State7=T
PORTD=0x00;
DDRD=0x30;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC2 output: Disconnected
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer 2 Stopped
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
GICR|=0x00;
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// Analog Comparator: Off
// Analog Comparator Output: Off
ACSR=0x80;
SFIOR=0x00;
// LCD module initialization
lcd_init(16);
while (1)
a=j%10;
b=((j-a)%100)/10;
c=(((j%1000)-(10*b+a))/100);
d=(((j%10000)-(100*c+10*b+a))/1000);
lcd_clear();
PORTB=0b00000000;
delay_ms(1000);
PORTB=0b11111111;
delay_ms(1000);
PORTB=0b00000000;
lcd_gotoxy(0,0); //desimal
lcd_putsf("inTheNameOfGod"
delay_ms(4600);
lcd_gotoxy(0,1); //desimal
lcd_putsf("ATMEGA 16/MT8870 "
delay_ms(5600);
lcd_putsf("codevision AVR C "
delay_ms(5600);
lcd_putsf("ST:m.Ghorbanali "
delay_ms(5600);
lcd_putsf("THRAN JNUB UNIT "
delay_ms(5600);
lcd_clear();
ali:
if (PIND.6==0)// zang ditect
PORTB=0b00000000;
delay_ms(500);
PORTB=0b11111111;
delay_ms(1550);
lcd_gotoxy(1,0);
lcd_putsf("sallam:"
PORTD.5=1; // relay
delay_ms(1000);
else
goto ali;
i=3,k=2,l=1,m==1;
lcd_clear();
lcd_clear();
e=0;
mohsen1:
if (PIND.7==1)// ton resived
delay_ms(100);
if (PIND.3==1 & PIND.2==0 & PIND.1==0 & PIND.0==0 )
i=1;
if (PIND.3==0 & PIND.2==1 & PIND.1==0 & PIND.0==0)
i=2;
if (PIND.3==1 & PIND.2==1 & PIND.1==0 & PIND.0==0 )
i=3;
if (PIND.3==0 & PIND.2==0 & PIND.1==1 & PIND.0==0 )
i=4;
if ( PIND.3==1 & PIND.2==0 & PIND.1==1 & PIND.0==0 )
i=5;
if ( PIND.3==0 & PIND.2==1 & PIND.1==1 & PIND.0==0 )
i=6;
if ( PIND.3==1 & PIND.2==1 & PIND.1==1 & PIND.0== 0 )
i=7;
if ( PIND.3==0 & PIND.2==0 & PIND.1==0 & PIND.0==1 )
i=8;
if ( PIND.3==1 & PIND.2==0 & PIND.1==0 & PIND.0==1 )
i=9;
if ( PIND.3==0 & PIND.2==1 & PIND.1==0 & PIND.0==1 )
i=0;
if ( PIND.3==1 & PIND.2==1 & PIND.1==0 & PIND.0==1 )
i=11;
if ( PIND.3==0 & PIND.2==0 & PIND.1==1 & PIND.0==1 )
i=12;
else
goto mohsen1;
delay_ms(1000);
mohsen2:
k=1;
k=2;
k=3;
k=4;
k=5;
k=6;
k=7;
k=8;
k=9;
k=0;
k=11;
k=12;
else
goto mohsen2;
delay_ms(1000);
mohsen3:
l=1;
l=2;
l=3;
l=4;
l=5;
l=6;
l=7;
l=8;
l=9;
l=0;
l=11;
l=12;
else
goto mohsen3;
delay_ms(1000);
mohsen4:
m=1;
m=2;
m=3;
m=4;
m=5;
m=6;
m=7;
m=8;
m=9;
m=0;
m=11;
m=12;
else
goto mohsen4;
// if ( i==d & k==c & l==b & m==a )
if ( i==3 & k==2 & l==1 & m==1 )
j=3211;
lcd_putsf("welcom:"
lcd_gotoxy(0,1);
lcd_puts(st);
itoa (j,st);
lcd_putsf("welcom:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(2000);
mohsen6:
delay_ms(800);
lcd_clear();
i=1;
i=2;
i=3;
i=4;
i=5;
i=6;
i=7;
i=8;
i=9;
i=0;
i=11;
i=12;
//************************************************** ****************************i give
if ( i==1)
itoa (i,st);
lcd_putsf("relay1 is on:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==2)
itoa (i,st);
lcd_putsf("relay1 is off:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==3)
itoa (i,st);
lcd_putsf("relay2 is on:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==4)
itoa (i,st);
lcd_putsf("relay2 is off:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==5)
itoa (i,st);
lcd_putsf("relay3 is on:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==6)
itoa (i,st);
lcd_putsf("relay3 is off:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==7)
itoa (i,st);
lcd_putsf("relay4 is on:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==8)
itoa (i,st);
lcd_putsf("relay4 is off:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==9)
itoa (i,st);
lcd_putsf("relay5 is on:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==0)
itoa (i,st);
lcd_putsf("relay5 is off:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
delay_ms(800);
//***********************************************bay bay
e=0;
for (e=0;e<255;e++)
goto mohsen6;
delay_ms(100);
lcd_clear();
lcd_putsf("good bay"
PORTD.5=0; // relay
delay_ms(1000);
goto ali;
else
goto mohsen6;
else
PORTD.5=0; // relay
lcd_putsf("no no!!!:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(1000);
goto ali;
#include <Stdlib.h>
#include <mega16.h>
#asm
#endasm
#include <lcd.h>
char st[10];
eeprom int j=3211 ;
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0xFF;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x30;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
GICR|=0x00;
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
ACSR=0x80;
SFIOR=0x00;
lcd_init(16);
while (1)
a=j%10;
b=((j-a)%100)/10;
lcd_clear();
PORTB=0b00000000;
delay_ms(1000);
PORTB=0b11111111;
delay_ms(1000);
PORTB=0b00000000;
delay_ms(4600);
delay_ms(5600);
delay_ms(5600);
delay_ms(5600);
delay_ms(5600);
lcd_clear();
ali:
PORTB=0b00000000;
delay_ms(500);
PORTB=0b11111111;
delay_ms(1550);
lcd_gotoxy(1,0);
lcd_putsf("sallam:"
PORTD.5=1; // relay
delay_ms(1000);
else
goto ali;
i=3,k=2,l=1,m==1;
lcd_clear();
lcd_clear();
e=0;
mohsen1:
delay_ms(100);
i=1;
i=2;
i=3;
i=4;
i=5;
i=6;
i=7;
i=8;
i=9;
i=0;
i=11;
i=12;
else
goto mohsen1;
delay_ms(1000);
mohsen2:
k=1;
k=2;
k=3;
k=4;
k=5;
k=6;
k=7;
k=8;
k=9;
k=0;
k=11;
k=12;
else
goto mohsen2;
delay_ms(1000);
mohsen3:
l=1;
l=2;
l=3;
l=4;
l=5;
l=6;
l=7;
l=8;
l=9;
l=0;
l=11;
l=12;
else
goto mohsen3;
delay_ms(1000);
mohsen4:
m=1;
m=2;
m=3;
m=4;
m=5;
m=6;
m=7;
m=8;
m=9;
m=0;
m=11;
m=12;
else
goto mohsen4;
j=3211;
lcd_putsf("welcom:"
lcd_gotoxy(0,1);
lcd_puts(st);
itoa (j,st);
lcd_putsf("welcom:"
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(2000);
mohsen6:
delay_ms(800);
lcd_clear();
i=1;
i=2;
i=3;
i=4;
i=5;
i=6;
i=7;
i=8;
i=9;
i=0;
i=11;
i=12;
if ( i==1)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==2)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==3)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==4)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==5)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==6)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==7)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==8)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==9)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
if ( i==0)
itoa (i,st);
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(500);
delay_ms(800);
e=0;
for (e=0;e<255;e++)
goto mohsen6;
delay_ms(100);
lcd_clear();
PORTD.5=0; // relay
delay_ms(1000);
goto ali;
else
goto mohsen6;
else
PORTD.5=0; // relay
lcd_gotoxy(5,1);
lcd_puts(st);
delay_ms(1000);
goto ali;
