عزیزان عظیم یه کمکی به ما کنین و به این چند تا سول من جواب بدین در این برنامه
' LED based Digital Clock
' By: Reza Sepas Yar (reza@avr.ir)
' Revision: 1.0
$regfile = "M32def.dat"
$crystal = 12000000
Dim Iloop As Word
Dim Row As Word
Dim Index As Word
Dim A As Word
Dim N As Word
Dim K As Word
Dim Ar1(512) As Byte
Dim Strg1 As String * 2
Dim Strg2 As String * 2
Dim Strg3 As String * 2
Dim Strg As String * 12
Dim Digits(12) As Byte At Strg Overlay
Ddra = &B11110000
Ddrb = 255
Ddrc = 255
Ddrd = 255
Config Scl = Porta.0
Config Sda = Porta.1
Const Ds1307w = &HD0
Const Ds1307r = &HD1
Dim _sec As Byte , _min As Byte , _hour As Byte
Dim _day As Byte , _month As Byte , _year As Byte
Dim Weekday As Byte , _min1 As Byte , _hour1 As Byte
Dim _weekday As Byte
Do
Gosub Getdatetime
Gosub Getdatetime
Strg1 = Bcd(_sec)
Strg2 = Bcd(_min)
Strg3 = Bcd(_hour)
Strg = Strg3 + ":" + Strg2 + ":" + Strg1
A = 1
For Iloop = 1 To 8
Gosub Filling
For K = 1 To 8
Read Ar1(a)
Incr A
Next
Next
For N = 1 To 100
For Row = 0 To 7
Portd = Ar1(1 + Row)
Set Portc.0
nop
Reset Portc.0
Portd = Ar1(9 + Row)
Set Portc.1
nop
Reset Portc.1
Portd = Ar1(17 + Row)
Set Portc.2
nop
Reset Portc.2
Portd = Ar1(25 + Row)
Set Portc.3
nop
Reset Portc.3
Portd = Ar1(33 + Row)
Set Portc.4
nop
Reset Portc.4
Portd = Ar1(41 + Row)
Set Portc.5
nop
Reset Portc.5
Portd = Ar1(49 + Row)
Set Porta.5
nop
Reset Porta.5
Portd = Ar1(57 + Row)
Set Porta.6
nop
Reset Porta.6
Reset Portb.row
Waitms 1
Set Portb.row
Next
Next
Loop
Filling:
Select Case Digits(iloop)
Case 32 : Gosub Space_char
Case 46 : Gosub Dot_char
Case 47 : Gosub Forward_char
Case 48 : Gosub 0_char
Case 49 : Gosub 1_char
Case 50 : Gosub 2_char
Case 51 : Gosub 3_char
Case 52 : Gosub 4_char
Case 53 : Gosub 5_char
Case 54 : Gosub 6_char
Case 55 : Gosub 7_char
Case 56 : Gosub 8_char
Case 57 : Gosub 9_char
Case 58 : Gosub Colon_char
Case Else : Gosub Space_char
End Select
Return
Space_char:
Restore Space_dta
Return
Dot_char:
Restore Point_dta
Return
Forward_char:
Restore Division_dta
Return
0_char:
Restore 0_dta
Return
1_char:
Restore 1_dta
Return
2_char:
Restore 2_dta
Return
3_char:
Restore 3_dta
Return
4_char:
Restore 4_dta
Return
5_char:
Restore 5_dta
Return
6_char:
Restore 6_dta
Return
7_char:
Restore 7_dta
Return
8_char:
Restore 8_dta
Return
9_char:
Restore 9_dta
Return
Colon_char:
Restore Colon_dta
Return
Getdatetime:
I2cstart
I2cwbyte Ds1307w
I2cwbyte 0
I2cstart
I2cwbyte Ds1307r
I2crbyte _sec , Ack
I2crbyte _min , Ack
I2crbyte _hour , Ack
I2crbyte Weekday , Ack
I2crbyte _day , Ack
I2crbyte _month , Ack
I2crbyte _year , Nack
I2cstop
_min1 = Makedec(_min)
_hour1 = Makedec(_hour)
Return
Setdate:
_day = Makebcd(_day)
_month = Makebcd(_month)
_year = Makebcd(_year)
I2cstart
I2cwbyte Ds1307w
I2cwbyte 3
I2cwbyte _weekday
I2cwbyte _day
I2cwbyte _month
I2cwbyte _year
I2cstop
Return
Settime:
_sec = Makebcd(_sec)
_min = Makebcd(_min)
_hour = Makebcd(_hour)
I2cstart
I2cwbyte Ds1307w
I2cwbyte 0
I2cwbyte _sec
I2cwbyte _min
I2cwbyte _hour
I2cstop
Return
End
Space_dta:
Data &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00 , &H00
Point_dta:
Data &H00 , &H00 , &H00 , &H00 , &H00 , &H18 , &H18 , &H00
Division_dta:
Data &H06 , &H0C , &H18 , &H30 , &H60 , &HC0 , &H80 , &H00
0_dta:
Data &H7C , &HCE , &HDE , &HF6 , &HE6 , &HC6 , &H7C , &H00
1_dta:
Data &H30 , &H70 , &H30 , &H30 , &H30 , &H30 , &HFC , &H00
2_dta:
Data &H78 , &HCC , &H0C , &H38 , &H60 , &HCC , &HFC , &H00
3_dta:
Data &H78 , &HCC , &H0C , &H38 , &H0C , &HCC , &H78 , &H00
4_dta:
Data &H1C , &H3C , &H6C , &HCC , &HFE , &H0C , &H1E , &H00
5_dta:
Data &HFC , &HC0 , &HF8 , &H0C , &H0C , &HCC , &H78 , &H00
6_dta:
Data &H38 , &H60 , &HC0 , &HF8 , &HCC , &HCC , &H78 , &H00
7_dta:
Data &HFC , &HCC , &H0C , &H18 , &H30 , &H30 , &H30 , &H00
8_dta:
Data &H78 , &HCC , &HCC , &H78 , &HCC , &HCC , &H78 , &H00
9_dta:
Data &H78 , &HCC , &HCC , &H7C , &H0C , &H18 , &H70 , &H00
Colon_dta:
Data &H00 , &H18 , &H18 , &H00 , &H00 , &H18 , &H18 , &H00
nop یعنی چه
Restore Space_dta یعنی جه
_sec = Makebcd(_sec) یعنی جه
ic ds1307 کارش چیه
oo: :angry:
oo: :angry:
oo: :angry:
oo: :angry:
' Revision: 1.0
$crystal = 12000000
Dim Iloop As Word
Dim Row As Word
Dim Index As Word
Dim A As Word
Dim N As Word
Dim K As Word
Ddra = &B11110000
Ddrb = 255
Ddrc = 255
Ddrd = 255
Do
Gosub Getdatetime
Gosub Getdatetime
Strg1 = Bcd(_sec)
Strg2 = Bcd(_min)
Strg3 = Bcd(_hour)
A = 1
For Iloop = 1 To 8
Gosub Filling
For K = 1 To 8
Read Ar1(a)
Incr A
Next
Next
For N = 1 To 100
For Row = 0 To 7
Set Portc.0
nop
Reset Portc.0
Set Portc.1
nop
Reset Portc.1
Set Portc.2
nop
Reset Portc.2
Set Portc.3
nop
Reset Portc.3
Set Portc.4
nop
Reset Portc.4
Set Portc.5
nop
Reset Portc.5
Set Porta.5
nop
Reset Porta.5
Set Porta.6
nop
Reset Porta.6
Reset Portb.row
Waitms 1
Set Portb.row
Next
Next
Loop
Filling:
End Select
Return
Space_char:
Restore Space_dta
Return
Dot_char:
Restore Point_dta
Return
Forward_char:
Return
0_char:
Restore 0_dta
Return
1_char:
Restore 1_dta
Return
2_char:
Restore 2_dta
Return
3_char:
Restore 3_dta
Return
4_char:
Restore 4_dta
Return
5_char:
Restore 5_dta
Return
6_char:
Restore 6_dta
Return
7_char:
Restore 7_dta
Return
8_char:
Restore 8_dta
Return
9_char:
Restore 9_dta
Return
Colon_char:
Restore Colon_dta
Return
Getdatetime:
I2cstart
I2cwbyte Ds1307w
I2cwbyte 0
I2cstart
I2cwbyte Ds1307r
I2crbyte _sec , Ack
I2crbyte _min , Ack
I2crbyte _day , Ack
I2cstop
Return
Setdate:
I2cstart
I2cwbyte Ds1307w
I2cwbyte 3
I2cwbyte _weekday
I2cwbyte _day
I2cwbyte _month
I2cwbyte _year
I2cstop
Return
Settime:
I2cstart
I2cwbyte Ds1307w
I2cwbyte 0
I2cwbyte _sec
I2cwbyte _min
I2cwbyte _hour
I2cstop
Return
End
Space_dta:
Point_dta:
Division_dta:
0_dta:
1_dta:
2_dta:
3_dta:
4_dta:
5_dta:
6_dta:
7_dta:
8_dta:
9_dta:
Colon_dta:
nop یعنی چه
ic ds1307 کارش چیه
