سلام من میخوام با میکرو یه مدار LED بارانی بسازم ..
چه کنم ؟؟
اگه کسی بلده کمکم کنه ..
زبان برنامه نویسی من بسکام هست
چه کنم ؟؟
$regfile = "m32def.dat" $crystal = 1000000 '1Mhz Config Porta = Output Config Portb = Output Config Portc = Output Config Portd = Output Do 'porta Set Porta.0 Delay Set Porta.1 Delay Set Porta.2 Delay Set Porta.3 Delay Reset Porta.0 Delay Set Porta.4 Delay Reset Porta.1 Delay Set Porta.5 Delay Reset Porta.2 Delay Set Porta.6 Delay Reset Porta.3 Delay Set Porta.7 Delay Reset Porta.4 Delay 'portb Set Portb.0 Delay Reset Porta.5 Delay Set Portb.1 Delay Reset Porta.6 delay Set Portb.2 Delay Reset Porta.7 delay Set Portb.3 Delay Reset Portb.0 delay Set Portb.4 Delay Reset Portb.1 delay Set Portb.5 delay Reset Portb.2 Delay Set Portb.6 Delay Reset Portb.3 Delay Set Portb.7 Delay Reset Portb.4 Delay 'portc Set Portc.0 Delay Reset Portb.5 delay Set Portc.1 Delay Reset Portb.6 delay Set Portc.2 delay Reset Portb.7 Delay Set Portc.3 delay Reset Portc.0 Delay Set Portc.4 delay Reset Portc.1 Delay Set Portc.5 Delay Reset Portc.2 Delay Set Portc.6 delay Reset Portc.3 Delay Set Portc.7 Delay Reset Portc.4 delay Reset Portc.5 Delay Reset Portc.6 Delay Reset Portc.7 Delay Loop
for(i=0;i<255;i++) { if(pin1>i) PORTB.0=1; else PORTB.0=0 }
