درود
من با stm32f103 با سرعت 73 مگ ال سی دی 4.3 اینج راه اندازی کردم
مشکل این هست که چرا سرعت انقدر پایینه
مثلا برای پاک کردم صفحه 1 تا 1.5 ثانیه طول میکشه
باید چیکار کنم که توی مثلا 50 میلی ثانیه یه عکس نمایش بده ؟؟؟
[LEFT]void LCD_Init(void) { SSD_RESET; //LCD_Configuration();lcd_write_command #define LCD_WriteCom LCD_WR_REG #define LCD_WriteRAM LCD_WR_DATA #define SSD1963_WriteCommand LCD_WriteCom #define SSD1963_WriteData LCD_WriteRAM #define TimeDelay(x) Delay_10ms(x/2) /*ssd1963?????*/ LCD_WriteCom(0x00E2); LCD_WriteRAM(0x0023); // Set PLL with OSC = 10MHz (hardware) // Multiplier N = 35, VCO (>250MHz)= OSC*(N+1), VCO = 360MHz LCD_WriteRAM(0x0001); // Divider M = 2, PLL = 360/(M+1) = 120MHz LCD_WriteRAM(0x0004); // Validate M and N values SSD1963_WriteCommand(SSD1963_SET_PLL_MN); SSD1963_WriteData(0x1D); // PLLclk = REFclk * 30 (300MHz) SSD1963_WriteData(0x02); // SYSclk = PLLclk / 3 (100MHz) SSD1963_WriteData(0x54); // dummy TimeDelay(1); LCD_WriteCom(0x00E0); // PLL enable LCD_WriteRAM(0x0001); TimeDelay(1); LCD_WriteCom(0x00E0); LCD_WriteRAM(0x0003); TimeDelay(1); LCD_WriteCom(0x0001); // software reset TimeDelay(1); LCD_WriteCom(0x00E6); LCD_WriteRAM(0x0004); LCD_WriteRAM(0x0093); LCD_WriteRAM(0x00e0); LCD_WriteCom(0x00B0); //LCD SPECIFICATION LCD_WriteRAM(0x0000); LCD_WriteRAM(0x0000); LCD_WriteRAM((HDP>>8)&0X00FF); //Set HDP LCD_WriteRAM(HDP&0X00FF); LCD_WriteRAM((VDP>>8)&0X00FF); //Set VDP LCD_WriteRAM(VDP&0X00FF); LCD_WriteRAM(0x0000); TimeDelay(1); LCD_WriteCom(0x00B4); //HSYNC LCD_WriteRAM((HT>>8)&0X00FF); //Set HT LCD_WriteRAM(HT&0X00FF); LCD_WriteRAM((HPS>>8)&0X00FF); //Set HPS LCD_WriteRAM(HPS&0X00FF); LCD_WriteRAM(HPW); //Set HPW LCD_WriteRAM((LPS>>8)&0X00FF); //Set HPS LCD_WriteRAM(LPS&0X00FF); LCD_WriteRAM(0x0000); TimeDelay(1); LCD_WriteCom(0x00B6); //VSYNC LCD_WriteRAM((VT>>8)&0X00FF); //Set VT LCD_WriteRAM(VT&0X00FF); LCD_WriteRAM((VPS>>8)&0X00FF); //Set VPS LCD_WriteRAM(VPS&0X00FF); LCD_WriteRAM(VPW); //Set VPW LCD_WriteRAM((FPS>>8)&0X00FF); //Set FPS LCD_WriteRAM(FPS&0X00FF); TimeDelay(1); LCD_WriteCom(0x00BA); LCD_WriteRAM(0x0005);//0x000F); //GPIO[3:0] out 1 TimeDelay(1); LCD_WriteCom(0x00B8); LCD_WriteRAM(0x0007); //GPIO3=input, GPIO[2:0]=output LCD_WriteRAM(0x0001); //GPIO0 normal TimeDelay(1); LCD_WriteCom(0x0036); //rotation LCD_WriteRAM(0x0008); TimeDelay(1); LCD_WriteCom(0x00F0); //pixel data interface LCD_WriteRAM(0x0003); TimeDelay(1); TimeDelay(1); LCD_WriteCom(0x0029); //display on TimeDelay(1); LCD_WriteCom(0x00BE); //set PWM for B/L LCD_WriteRAM(0x0006); LCD_WriteRAM(0x0080); TimeDelay(1); LCD_WriteRAM(0x0001); LCD_WriteRAM(0x00f0); LCD_WriteRAM(0x0000); LCD_WriteRAM(0x0000); TimeDelay(1); LCD_WriteCom(0x00d0);//?????????? LCD_WriteRAM(0x000d); TimeDelay(1);[/LEFT] //LCD_Clear(BLACK); }
