figure capture
    figure capture
    فرض کنین یه تابع مثله sin کشیدیم ... حالا می خایم اون فیگور ( پنجره نمایش ) رو به طور کل save کنیم . دقت کینن با استفاده از دستور ... نه موس و ...
    ممنون می شم راهنمایی کنید
    به دلیل رعایت نکردن قوانین ، امضا ویرایش شد.
    پاسخ : figure capture
    Example 1: Specify File Extension
    Save the current figure that you annotated using the Plot Editor to a file named pred_prey using the MATLAB fig
    format. This allows you to open the file pred_prey.fig at a later time and continue editing it with the Plot Editor.
    saveas(gcf,'pred_prey.fig&#039
    Example 2: Specify File Format but No Extension
    Save the current figure, using Adobe Illustrator format, to the file logo. Use the ai extension from the above table to
    specify the format. The file created is logo.ai.
    saveas(gcf,'logo', 'ai&#039
    This is the same as using the Adobe Illustrator format from the print devices table, which is -dill; use doc print or
    help print to see the table for print device types. The file created is logo.ai. MATLAB automatically appends the ai
    extension for an Illustrator format file because no extension was specified.
    saveas(gcf,'logo', 'ill&#039
    Example 3: Specify File Format and Extension
    Save the current figure to the file star.eps using the Level 2 Color PostScript format. If you use doc print or help
    print, you can see from the table for print device types that the device type for this format is -dpsc2. The file created is
    star.eps.
    saveas(gcf,'star.eps', 'psc2&#039
    In another example, save the current ******** block diagram to the file trans.tiff using the TIFF format with no
    compression. From the table for print device types, you can see that the device type for this format is -dtiffn. The file
    created is trans.tiff.
    saveas(gcf,'trans.tiff', 'tiffn&#039
    End
