من بردکاربردی صنعتی رو دارم (SIM900)
این سورس برنامه ولی کار نمیده :
CodeWizardAVR V2.04.4a Advanced
Automatic Program Generator
© Copyright 1998-2009 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 2013/07/22
Author : NeVaDa
Company :
Comments:
Chip type : ATmega128
Program type : Application
Memory model : Small
External RAM size : 0
Data Stack size : 1024
#include <mega128.h>
// Standard Input/Output functions
#include <stdio.h>
#include <string.h>
char phone[20];
char sms_text[256];
char Enter=13;
char double_quote=34;
char Ctrlz=26;
char text1[250];
void main(void)
// Port A initialization
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Port E initialization
PORTE=0x00;
DDRE=0x00;
// Port F initialization
PORTF=0x00;
DDRF=0x00;
// Port G initialization
// Func4=In Func3=In Func2=In Func1=In Func0=In
// State4=T State3=T State2=T State1=T State0=T
PORTG=0x00;
DDRG=0x00;
// Clock source: System Clock
// Mode: Normal top=FFh
// OC0 output: Disconnected
ASSR=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// OC1C output: Discon.
// Noise Canceler: Off
// Compare C Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
// OC2 output: Disconnected
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer/Counter 3 initialization
// Clock value: Timer3 Stopped
// OC3A output: Discon.
// OC3B output: Discon.
// OC3C output: Discon.
// Timer3 Overflow Interrupt: Off
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
TIMSK=0x00;
ETIMSK=0x00;
// USART0 initialization
// USART0 Receiver: On
// USART0 Transmitter: Off
// USART0 Mode: Asynchronous
// USART0 Baud Rate: 9600
UCSR0A=0x00;
UCSR0B=0x10;
UCSR0C=0x06;
UBRR0H=0x00;
UBRR0L=0x33;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
printf("AT+CMGF=1%c",Enter);
scanf("%s",text1);
// Place your code here
strcpy(phone,"0919********"
printf("AT+CMGS=%c%s%c%c",double_quote,p hone,double_quote,Enter);
scanf("%s",text1);
strcpy(sms_text,"This is a test message - ECA Co"
printf("%s%c",sms_text,Ctrlz);
scanf("%s",text1);
scanf("%s",text1);
while (1)
ولی اس نمیده
خودم احتمال میدم مشکل از چندجا باشه:
1. ورودی یا خروجی بودن یا نبودن پایه ها
2.تنظیمات یوزارت
3.فیوزبیت ها رو قبلا دستکاری کردم و دیفالتشونو ندارم.
4. مدارم که البته درسته :
پورت 9 ماژول مستقیم به پورت 2 میکرو (ATMEGA128)
پورت 10 ماژول مستقیم به پورت 3 میکرو (ATMEGA128)
آداپتر 12 ولت دوآمپر به ماژول (کاربردی صنعتی)
5 ولت به VCC میکرو
و نیز اتصال GND میکرو و ماژول
چیزی نمیخواد پول پ باشه؟؟ مدار کافیه؟؟
شبکه رو هم میشناسه و زنگ هم میخوره
نمیخواد شمارم شکل دیگه ای باشه؟
ممنون لطفا مدیران حذف نکنند
Project :
Version :
Date : 2013/07/22
Author : NeVaDa
Company :
Comments:
#include <stdio.h>
#include <string.h>
char phone[20];
char sms_text[256];
char Enter=13;
char Ctrlz=26;
char text1[250];
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
PORTE=0x00;
DDRE=0x00;
PORTF=0x00;
DDRF=0x00;
PORTG=0x00;
DDRG=0x00;
ASSR=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
TIMSK=0x00;
ETIMSK=0x00;
UCSR0A=0x00;
UCSR0B=0x10;
UCSR0C=0x06;
UBRR0H=0x00;
UBRR0L=0x33;
ACSR=0x80;
SFIOR=0x00;
scanf("%s",text1);
scanf("%s",text1);
scanf("%s",text1);
scanf("%s",text1);
while (1)
ولی اس نمیده
2.تنظیمات یوزارت
5 ولت به VCC میکرو
