نحوه ی ارتباط مموری sdبا میکرو AVR
    #31
    پاسخ : نحوه ی ارتباط مموری sdبا میکرو AVR
    سلام،اقا من تو پروژه که تو پوشه examplesخود کدویژن هستش با نام sdcard4دیدم که پایه ی CD رو به تایمر 1 وصل کرده و اونوقت تایمر 1 رو پیکربندی کرده.ضمنا اصلا ابتدای برنامه spi رو کانفیک نکرده .میشه یه توضیح راجع بهش بدید.آخه من مدارم رو بستم و CD رو هم به پایه SS متصل کردم.الیته من با atmega32 بستم.
    [right]/******************************************************************************
    Creation, attribute and time stamp changing of a file on a MMC/SD/SD HC card
    example for the CodeVisionAVR V2.04.4+ compiler
    (C) 2009 HP InfoTech s.r.l., Pavel Haiduc
    The example is intended to be run on the Mega128-Dev development board
    from www.priio.com.
    The development board uses an ATmega128 chip running at 14.745600 MHz
    The SD card socket on the development board is connected to the
    following I/O ports:
    SD socket  CD4050  ATmega128
    pin1 /CS -----<|----- PORTD bit6
    pin2 SI -----<|----- MOSI
    pin3 GND
    pin4 +3.3V
    pin5 SCK -----<|----- SCK
    pin6 GND
    pin7 SO ------------ MISO
    pin9 GND
    pin10 CD ------------ PORTG bit4 with 10k pull-up resistor to +5V
    pin11 WP ------------ PORTG bit3 with 10k pull-up resistor to +5V
    pin12 GND
    The CD4050 CMOS buffer is powered from a +3.3V supply and
    performs logic level translation from 5V (AVR) to 3.3V (SD card).
    For other I/O port connections, you need to make appropriate changes in the
    "Project|Configure|C Compiler|Libraries|MMC/SD/SD HC Card and FAT Support"
    menu.
    The development board also uses a PCF8563 RTC connected to the
    PCF8563        ATmega128
    pin5 SDA ------------- PORTD bit1 with 10k pull-up resistor to +5V
    pin6 SCL ------------- PORTD bit0 with 10k pull-up resistor to +5V
    The development board's serial socket P9 must be connected to the PC COM port.
    The CodeVisionAVR Terminal is used for displaying data received from the
    development board.
    The Terminal must be configured for:
    Baud Rate: 19200
    Data Bits: 8
    Parity: None
    Stop Bits: 1
    Emulation: TTY
    Handshaking: None
    Append LF on Reception: OFF
    Appearance|Rows: 40
    Appearance|Columns: 80
    If you are using the CodeVisionAVR Evaluation version, you may program into
    the FLASH the precompiled SDCARD4.HEX file found in the
    \Examples\SDCARD4\EXE directory
    /* ATmega128 I/O register definitions */
    #include <mega128.h>
    /* FAT on MMC/SD/SD HC card support */
    #include <ff.h>
    /* printf */
    #include <stdio.h>
    /* PCF8563 RTC functions*/
    #include <PCF8563.h>
    /* The PCF8563 RTC on the I2C bus is connected to ATmega128 PORTD
      SDA - PORTD.1
      SCL - PORTD.0
    #asm
      .equ __i2c_port=0x12
      .equ __sda_bit=1
      .equ __scl_bit=0
    #endasm
    /* Timer1 overflow interrupt frequency [Hz] */
    #define T1_OVF_FREQ 100
    /* Timer1 clock prescaler value */
    #define T1_PRESC 1024L
    /* Timer1 initialization value after overflow */
    #define T1_INIT (0x10000L-(_MCU_CLOCK_FREQUENCY_/(T1_PRESC*T1_OVF_FREQ)))
    /* USART Baud rate */
    #define BAUD_RATE 19200
    #define BAUD_INIT (_MCU_CLOCK_FREQUENCY_/(BAUD_RATE*16L)-1)
    /* FAT function result */
    FRESULT res;
    /* number of bytes written/read to the file */
    unsigned int nbytes;
    /* will hold the information for logical drive 0: */
    FATFS fat;
    /* will hold the file information */
    FIL file;
    /* will hold file attributes, time stamp information */
    FILINFO finfo;
    /* file path */
    char path[]="0:/file.txt";
    /* text to be written to the file */
    char text[]="I like CodeVisionAVR!";
    /* file read buffer */
    char buffer[256];
    /* 100Hz timer interrupt generated by ATmega128 Timer1 overflow */
    interrupt [TIM1_OVF] void timer_comp_isr(void)
    /* re-initialize Timer1 */
    TCNT1H=T1_INIT>>8;
    TCNT1L=T1_INIT&0xFF;
    /* card access low level timing function */
    disk_timerproc();
    /* error message list */
    flash char * flash error_msg[]=
    "", /* not used */
    "FR_DISK_ERR",
    "FR_INT_ERR",
    "FR_INT_ERR",
    "FR_NOT_READY",
    "FR_NO_FILE",
    "FR_NO_PATH",
    "FR_INVALID_NAME",
    "FR_DENIED",
    "FR_EXIST",
    "FR_INVALID_OBJECT",
    "FR_WRITE_PROTECTED",
    "FR_INVALID_DRIVE",
    "FR_NOT_ENABLED",
    "FR_NO_FILESYSTEM",
    "FR_MKFS_ABORTED",
    "FR_TIMEOUT"
    /* display error message and stop */
    void error(FRESULT res)
    if ((res>=FR_DISK_ERR) && (res<=FR_TIMEOUT))
      printf("ERROR: %p\r\n",error_msg[res]);
    /* stop here */
    while(1);
    /* display file's attribute, size and time stamp */
    void display_status(char *file_name)
    if ((res=f_stat(file_name,&finfo))==FR_OK)
      printf("File: %s, Attributes: %c%c%c%c%c\r\n"
         "Date: %02u/%02u/%u, Time: %02u:%02u:%02u\r\n"
         "Size: %lu bytes\r\n",
         finfo.fname,
         (finfo.fattrib & AM_DIR) ? 'D' : '-',
         (finfo.fattrib & AM_RDO) ? 'R' : '-',
         (finfo.fattrib & AM_HID) ? 'H' : '-',
         (finfo.fattrib & AM_SYS) ? 'S' : '-',
         (finfo.fattrib & AM_ARC) ? 'A' : '-',
         finfo.fdate & 0x1F, (finfo.fdate >> 5) & 0xF,
         (finfo.fdate >> 9) + 1980,
         (finfo.ftime >> 11), (finfo.ftime >> 5) & 0x3F,
         (finfo.ftime & 0xF) << 1,
         finfo.fsize);
    else
      /* an error occured, display it and stop */
      error(res);
    void main(void)
    /* initialize Timer1 overflow interrupts in Mode 0 (Normal) */
    TCCR1A=0x00;
    /* clkio/1024 */
    TCCR1B=(1<<CS12)|(1<<CS10);
    /* timer overflow interrupts will occur with 100Hz frequency */
    TCNT1H=T1_INIT>>8;
    /* enable Timer1 overflow interrupt */
    TIMSK=1<<TOIE1;
    /* initialize the USART0 TX, 8N1, Baud rate: 19200 */
    UCSR0A=0;
    UCSR0B=1<<TXEN0;
    UCSR0C=(1<<UCSZ01)|(1<<UCSZ00);
    UBRR0H=BAUD_INIT>>8;
    UBRR0L=BAUD_INIT&0xFF;
    /* init the PCF8563 RTC */
    rtc_init(0,RTC_CLKOUT_OFF,RTC_TIMER_OFF);
    /* init the pointer to the RTC function used for reading time */
    prtc_get_time=(void (*)(unsigned char *,unsigned char *,unsigned char *)) rtc_get_time;
    prtc_get_date=(void (*)(unsigned char *,unsigned char *,unsigned int *)) rtc_get_date;
    /* globally enable interrupts */
    #asm("sei")
    /* mount logical drive 0: */
    if ((res=f_mount(0,&fat))==FR_OK)
      printf("Logical drive 0: mounted OK\r\n");
    else
      error(res);
    /* create a new file in the root of drive 0:
    and set write access mode */
    if ((res=f_open(&file,path,FA_CREATE_ALWAYS | FA_WRITE))==FR_OK)
      printf("File %s created OK\r\n",path);
    else
      error(res);
    /* write some text to the file,
    without the NULL string terminator sizeof(data)-1 */
    if ((res=f_write(&file,text,sizeof(text)-1,&nbytes))==FR_OK)
      printf("%u bytes written of %u\r\n",nbytes,sizeof(text)-1);
    else
      error(res);
    /* close the file */
    if ((res=f_close(&file))==FR_OK)
      printf("File %s closed OK\r\n",path);
    else
      error(res);
    /* open the file in read mode */
    if ((res=f_open(&file,path,FA_READ))==FR_OK)
      printf("File %s opened OK\r\n",path);
    else
      error(res);
    /* read and display the file's content.
    make sure to leave space for a NULL terminator
    in the buffer, so maximum sizeof(buffer)-1 bytes
    can be read */
    if ((res=f_read(&file,buffer,sizeof(buffer)-1,&nbytes))==FR_OK)
      printf("%u bytes read\r\n",nbytes);
      /* NULL terminate the char string in the buffer */
      buffer[nbytes+1]=NULL;
      /* display the buffer contents */
      printf("Read text: \"%s\"\r\n",buffer);
    else
      error(res);
    else
      error(res);
    display_status(path);
    /* change file's attributes, set the file to be Read-Only */
    if ((res=f_chmod(path,AM_RDO,AM_RDO))==FR_OK)
      printf("Read-Only attribute set OK\r\n",path);
    else
      error(res);
    /* change file's time stamp */
    #define DAY (6)
    #define MONTH (3)
    #define YEAR (2000)
    #define SECOND (0)
    #define MINUTE (40)
    #define HOUR (14)
    finfo.fdate=DAY | (MONTH<<5) | ((YEAR-1980)<<9);
    finfo.ftime=(SECOND>>1) | (MINUTE<<5) | (HOUR<<11);
    if ((res=f_utime(path,&finfo))==FR_OK)
      printf("New time stamp %02u/%02u/%u %02u:%02u:%02u set OK\r\n",
      DAY,MONTH,YEAR,HOUR,MINUTE,SECOND);
    else
      error(res);
    /* display file's new attribute and time stamp */
    /* change file's attributes, clear the Read-Only attribute */
    if ((res=f_chmod(path,0,AM_RDO))==FR_OK)
      printf("Read-Only attribute cleared OK\r\n",path);
    else
      error(res);
    /* stop here */
    while(1);
    [/right]
      #32
      کسی جواب نمیده؟ :angry:
        #33
        :NO:
        من قبلا میکرو mega32 رو به MMC وصل کردم ولی با SD نتونستم کار کنم
        چار فرانسه نباش
          #34
          سلام دوستان.کسی که ما رو تحویل نمی گیره و جوابمون رو نمی ده.فکر کنم مشکل من کم آوردن SRAM مگا 32 هستش واسه همین تصمیم گرفتم که از atmega128 استفاده کنم.فقط یه سوال:آیا باید حتما تو پروژه از ای سی ساعت استقاده کنم؟یعنی بدون اون و بدون اینکه بخوام از تایمر استفاده کنم نمیشه با توابع ff.h تو کدویژن کار کرد؟اخه تو help کدویژن نوشته که توابع fat به یک ساعت بلادرنگ نیاز دارند.
            #35
            راستش من با کتابخونه ی کدویژن کار نکردم و در موردش نظری ندارم اما در مورد بودن ساعت مطمئن هستم.
            اگه ساعت نباشه وقتی یه فایلی رو درست میکنید فیلد زمان تولید رو باچی میخواید پر کنید؟؟
            یا از یه آیسی ساعت استفاده کن و یا تایمر 2 رو تو حالت RTC راه بنداز.
              #36
              مرسی شاهین جان،اما من مدارم رو بستم واسه همین نمی تونم دیگه از ساعت استفاده کنم.بنابراین باید برم سراغ همون تایمر 2.اگه بخوام از تایمر 2 استقاده کنم چه طور باید پیکربندی کنم؟ضمنا چه طور باید ازش مقدار رو بخونم و به توابع FAT اعلامش کنم؟
                #37
                شما باید یه کریستال ساعت به پایه های TOSC1 وTOSC2 وصل کنید.بعد با ریجستر ASSR پالس خارجی رو راه اندازی میکنید.خود تایمر روهم روی حالت معمولی و فکر کنم تقسیم کننده 128 تنظیم میکنید و وقفه رو هم فعال کنید.بعد خودتون باید با استفاده از وقفه هایی که تایمر تولید میکنه ساعت رو درست کنید.یعنی وقتی ثانیه به 60 رسید ثانیه صفر بشه و دقیقه اضافه شه و......
                توی هلپ کدویژن ببینید چه توابعی رو لازم داره و اونا رو بنویسید.چون من از این کتابخونه استفاده نکردم نمیدونم چه توابعی رو میخواد.
                  #38
                  آقا مشکل حل شد.باید به جای استفاده از پایه SS از تایمر یک باتقسیم فرکانس بر 1024 استفاده می کردم.بنابر این باید پایه CS از مموری SD رو به PB.1 (خروجی تایمر یک) وصل می کردم
                    #39
                    نوشته اصلی توسط En_sasan
                    خداروشکر.
                    می شه برنامه و مدار رو بذارید همه استفاده کنن؟
