سلام بر اساتید
این خط
وقتی میکرو به این خط میرسه هیچ عملی انجام نمیده (به خط های زیرین نمیره)
کار این دستور چی هست مال mp3 پلیر با vs1003 هست
این هم بقیه برنامه
' MP_3_PLAYER with VS1001k FOR MP3.FILES FORMAT Name 8.3 FAT16 AVR-DOS 5.5
' data 14-06-2007 versione BASCOM 1.8.11.3 AVR-DOS 5.5
' written by GIOVANNI DE LUCA
' HTTP://delucagiovanni.interfree.it robot applications and others
' HTTP://WWW.LNS.INFN.IT nuclear phisics applications
' HTTP://www.youtube.com/tubincolo my video mobile-robots
' deluca@lns.infn.it my e-mail
' to control it's used serial port com1 and pul "UP" to change songs
' to make test I used 64Mb MMC with 20 songs in the MMC
' but I thing that it's possible read bigger MMC memory without problem
$prog &HFF , &H4F , &HC5 , &HFF 'FUSE BITS generated
$regfile = "M64def.dat " 'IT'S POSSIBLE USE DIFFERENT AVR-CHIPS
$crystal = 14745600 'BUT this NOT TESTED
$baud = 115200
$swstack = 256
$hwstack = 256
$framesize = 768
Config Timer1 = Timer , Prescale = 64
Config Clock = Soft
Enable Interrupts
Enable Timer1
Enable Urxc 'abilita rs232
On Timer1 Timer_1
On Urxc Rs_232 'salto per rs232
Config Date = Dmy , Separator = .
Avanti Alias Ping.0 'tashih shavad
Led Alias Portc.6 'tshih shavad
Vs_miso Alias Ping.1
Vs_mosi Alias Portc.0
Vs_clock Alias Portc.1
Xcs Alias Portc.2
Xreset Alias Portc.3
Dreq Alias Pinc.4
Bsync Alias Portc.5
Config Avanti = Input 'pulsante avanti
Config Led = Output 'led
Config Vs_miso = Input 'serial input vs-1001
Config Vs_mosi = Output 'serial out vs-1001
Config Vs_clock = Output 'serial clock vs-1001
Config Xcs = Output 'VS Chip Select
Config Xreset = Output 'VS Reset
Config Dreq = Input 'VS Data Request
Config Bsync = Output 'VS Stream Request
Declare Sub Vs_init()
Declare Sub Soft_reset()
Declare Sub Vs_write(byval Vs_address As Byte , Byval Data1 As Byte , Byval Data2 As Byte)
Declare Function Vs_read(byval Vs_address As Byte) As Word
Declare Sub Send_mp3(byval Filename As String)
Const Vs_rd = &B0000_0011 'Write command vs1001
Const Vs_wr = &B0000_0010 'Read command vs1001
Const Vs_mode = 0
Const Vs_status = 1
Const Vs_clockf = 3
Const Vs_decode_time = 4
Const Vs_audata = 5
Const Vs_volume = 11
Config Lcdpin = Pin , Db4 = Pinf.4 , Db5 = Pinf.5 , Db6 = Pinf.6 , Db7 = Pinf.7 , E = Pinf.2 , Rs = Pinf.3
Config Lcd = 16 * 2
Dim B As Byte
Dim I As Integer
Dim J As Long
Dim Curbyte As Long
Dim S As String * 20
Dim Sample_rate As Word
Dim Bit_rate As Word
Dim Is_stereo As Word
Dim Audata As Word
Dim Filename As String * 11
Dim Mmc_data(512) As Byte '512 byte
Dim Tempo_new As Word
Dim Tempo_old As Word
Dim Flag_read As Bit
Dim Flag_play As Bit
Dim Comando As String * 10
Dim Mode_low As Byte
Dim Mode_hig As Byte
Dim Volume As Word
Dim Volume_low As Byte
Dim Volume_hig As Byte
'Do
'Waitms 500
'Toggle Led
'Print "Hi World..."
'Print
'Loop
Cls
Lcd "lcd is ok"
Wait 1
Cls
$include "Config_AVR-DOS.BAS"
$include "Config_MMC.bas"
B = Drivereset()
B = Driveinit()
$external Waitms 'include mmc
If Gbdriveerror <> 0 Then End
Lcd "0" 'include avr-dos
B = Initfilesystem(1)
Lcd "1" 'init file system
If B <> 0 Then Print "Errore MMC" 'se errore
Lcd "2"
Bsync = 0
Xreset = 0
Xcs = 1
Portg.0 = 1 'res pull up
Flag_play = 0 'sta suonando ?
Flag_read = 1 'gia letto ?
'-------------------------- PROGRAM START -------------------------------------
Print "Dir *.mp3" 'dir mp3
Print
'---------------------- crea una lista dei brani mp3 presenti sulla MMC --------
Open "Lista.txt" For Output As #9
'create file.list in MMC
S = Dir( "*.mp3"
While Len(s) > 0
Print S ; " " ; Filedate() ; " " ; Filetime() ; " " ; Filelen()
Print #9 , S 'memorizza la lista
S = Dir()
Wend
Close #9
Print "VS1001 Init"
Vs_init 'reset hardware e inizializza
'--------------------------- MAIN PROGRAMM -------------------------------------
Open "Lista.txt" For Input As #9 'OPEN LA LISTA
While Eof(#9) = 0
Line Input #9 , S 'READ filename Mp3
Call Send_mp3(s) 'play mp3
Wend
Close #9
End
'---------------------------- TIMER 1 ------------------------------------------
Timer_1:
If Bsync = 0 And Flag_play = 1 And Flag_read = 1 Then 'per leggere inforamzioni
Flag_read = 0
Audata = Vs_read(vs_audata)
Sample_rate = Audata And &H1E00
Rotate Sample_rate , Right , 9
Bit_rate = Audata And &H1FF
Is_stereo = Audata And &H8000
Rotate Is_stereo , Right , 15
Print Sample_rate ; "," ; Bit_rate ; " Kbs," ; Is_stereo 'print informations
End If
If Bsync = 0 And Flag_play = 1 And Flag_read = 0 Then
Tempo_new = Vs_read(vs_decode_time)
If Tempo_new <> Tempo_old Then Print Tempo_new ; " Sec"
Tempo_old = Tempo_new
End If
Return
'---------------------- RS 232 -------------------------------------------------
Rs_232:
Comando = Inkey()
If Comando = "1" Then
Mode_low.7 = 1 'set to zero
Bsync = 0
Vs_write Vs_mode , &H0 , Mode_low 'no loudness
End If
If Comando = "2" Then
Mode_low.7 = 0 'set to zero
Bsync = 0
Vs_write Vs_mode , &H0 , Mode_low 'loudness
End If
If Comando = "3" Then
Mode_low.1 = 0
Bsync = 0
Vs_write Vs_mode , &H0 , Mode_low 'play normale
End If
If Comando = "4" Then
Mode_low.1 = 1
Bsync = 0
Vs_write Vs_mode , &H0 , Mode_low 'play veloce
End If
If Comando = "5" And Volume_low < 250 Then
Volume_hig = Volume_hig + 5
Volume_low = Volume_low + 5
Bsync = 0
Vs_write Vs_volume , Volume_hig , Volume_low 'volume down
End If
If Comando = "6" And Volume_low > 0 Then
Volume_hig = Volume_hig - 5
Volume_low = Volume_low - 5
Bsync = 0
Vs_write Vs_volume , Volume_hig , Volume_low 'volume up
End If
Comando = ""
Return
'------------------------------ MP3 SUBROUTINES --------------------------------
Xcs = 0 'Xcs low
B = Vs_rd
Shiftout Vs_mosi , Vs_clock , B , 1
Shiftout Vs_mosi , Vs_clock , Vs_address , 1
B = 0
Shiftin Vs_miso , Vs_clock , B , 1
Vs_read = B
Shift Vs_read , Left , 8
B = 0
Vs_read = Vs_read + B
Xcs = 1 'Xcs high
End Function
'-------------------------------- WRITE ROUTINE --------------------------------
Xcs = 0
B = Vs_wr
Shiftout Vs_mosi , Vs_clock , Data1 , 1
Shiftout Vs_mosi , Vs_clock , Data2 , 1
Xcs = 1
End Sub
'------------------------------- RESETTA E INIZILIZZA --------------------------
Sub Vs_init()
Xreset = 0
Waitms 5
Xreset = 1
Waitms 10
Do : Led = Dreq : Loop Until Dreq = 1
Vs_write Vs_mode , &H0 , &H4 'reset
Vs_write Vs_mode , &H0 , &H0
Vs_write Vs_mode , &H4 , Mode_low 'bass
Vs_write Vs_mode , &H4 , &H40
Vs_write Vs_clockf , &H9B , &HE8 'clockf 12.288 MHz VS1003
Vs_write Vs_volume , &H00 , &H00 'volume =0 massimo
End Sub
'--------------------------- SOFT RESET VS1001 ---------------------------------
Sub Soft_reset
Do : Led = Dreq : Loop Until Dreq = 1 'wait Dreq
End Sub
'---------------------------- SEND FILE MP3 ------------------------------------
Print "Play : " ; Filename
Soft_reset 'resetta vs1001
Flag_read = 1 'per leggere una volta sample rate etc
Flag_play = 0 'inizia a leggere dopo che è stato letto il primo pacchetto
Open Filename For Binary As #10 'apri il file mp3 e play song
While Eof(#10) = 0
Get #10 , Mmc_data(1) , , 512 'preleva 512 byte
For I = 1 To 16
For J = 1 To 32
Bsync = 1
Shiftout Vs_mosi , Vs_clock , Mmc_data(curbyte) , 1
Bsync = 0
Incr Curbyte
Next J
Next I 'first 32
Curbyte = 1 'after 16 16x32=512 byte
If Avanti = 0 Then Goto Esci 'pulsante up
Flag_play = 1 'playing primo pacchetto
Wend
Esci:
Flag_play = 0 'stop play
Close #10
For I = 1 To 2048 'send 2048 zeros to clear buffer
B = 0
Shiftout Vs_mosi , Vs_clock , B , 1 'send 2048 byte
Next I
Print "MP3 End" 'end song
Waitms 100 'aspetta 100
End Sub
این خط
این هم بقیه برنامه
$baud = 115200
$swstack = 256
$hwstack = 256
$framesize = 768
Config Clock = Soft
Enable Interrupts
Enable Timer1
On Timer1 Timer_1
Xcs Alias Portc.2
Dreq Alias Pinc.4
Bsync Alias Portc.5
Const Vs_mode = 0
Const Vs_status = 1
Const Vs_clockf = 3
Const Vs_audata = 5
Config Lcd = 16 * 2
Dim B As Byte
Dim I As Integer
Dim J As Long
Dim Curbyte As Long
Dim Audata As Word
Dim Volume As Word
'Do
'Waitms 500
'Toggle Led
'Print
'Loop
Cls
Lcd "lcd is ok"
Wait 1
Cls
B = Drivereset()
B = Driveinit()
Lcd "2"
Bsync = 0
Xreset = 0
Xcs = 1
S = Dir( "*.mp3"
While Len(s) > 0
S = Dir()
Wend
Close #9
Print "VS1001 Init"
While Eof(#9) = 0
Wend
Close #9
End
Timer_1:
Flag_read = 0
End If
End If
Return
Rs_232:
Comando = Inkey()
Bsync = 0
End If
Bsync = 0
End If
Mode_low.1 = 0
Bsync = 0
End If
Mode_low.1 = 1
Bsync = 0
End If
Bsync = 0
End If
Bsync = 0
End If
Comando = ""
Return
Xcs = 0 'Xcs low
B = Vs_rd
B = 0
Vs_read = B
B = 0
Xcs = 1 'Xcs high
End Function
Xcs = 0
B = Vs_wr
Xcs = 1
End Sub
Sub Vs_init()
Xreset = 0
Waitms 5
Xreset = 1
Waitms 10
End Sub
Sub Soft_reset
End Sub
While Eof(#10) = 0
For I = 1 To 16
For J = 1 To 32
Bsync = 1
Bsync = 0
Incr Curbyte
Next J
Next I 'first 32
Wend
Esci:
Close #10
B = 0
Next I
End Sub
