IAR Embedded Workbench for ARM v6.10.1
    IAR Embedded Workbench for ARM - powerful and efficient development environment for ARM microcontrollers in the language C, C and assembler. The composition of the development environment includes a compiler, linker and debugger. Additional tools and a good built-in help system further facilitate the writing of programs. It provides extensive support for ARM devices and generates very compact and efficient code.Source Editor
    - Convenient user interface;
    - Automatic allocation errors;
    - Customizable toolbar;
    - Allocation directives C / C;
    - Advanced search tools.
    Compiler for C / C
    - One of the best compilers on the effectiveness of the code;
    - Full compatibility with ANSI C;
    - Several models for the efficient allocation of memory;
    - Optimization algorithms specifically for ARM-based microcontrollers;
    - Language extensions for embedded systems.
    Assembler
    - Integrated Macroassembler for real-time applications;
    - Includes a compiler preprocessor for C.
    Linker
    - Supports full layout, placement, and the creation of the format;
    - Supports more than 30 standard output formats for use with in-circuit emulator;
    - Load modules only when needed.
    Simulator and debugger
    - Debugging in codes C, C and assembler;
    - Multiple breakpoints;
    - Language descriptions of peripherals and I / O operations;
    - View domains CODE, DATA, EEPROM registers and I / O;
    - Interrupt Handling with the prediction;
    - Control all the variables and the stack;
    - Complex data types.
    Supported kernels:
    - ARM7 (ARM7TDMI, ARM7TDMI-S, ARM720T);
    - ARM7E (ARM7EJ-S);
    - ARM9 (ARM9TDMI, ARM920T, ARM922T, ARM940T);
    - ARM9E (ARM926EJ-S, ARM946E-S, ARM966E-S, ARM968E-S);
    - ARM10E (ARM1020E, ARM1022E);
    - ARM11;
    - SecurCore (SC000, SC100, SC110, SC200, SC210, SC300);
    - Cortex-M1;
    - Cortex-M3;
    - Cortex-R4;
    - Cortex-M0;
    - Cortex-M4;
    - XScale;
    - Cortex-A5.
    The main innovations:
    - Implemented full support for C, compliant with ISO / IEC 14882:2003;
    - Added support for microcontrollers c core Cortex-A5.
    System requirements
    - Operating system Microsoft Windows XP (SP3), Vista (SP2) or Windows 7.
    - 1 GB RAM and 2 GB of free disk space.
    - Adobe Acrobat Reader, to access the product documentation.
    Download
    http://hotfile.com/dl/86887584/ab382fb/IAR_EW_ARM_6.10.1.part1.rar.html
    http://hotfile.com/dl/86887567/6b48d25/IAR_EW_ARM_6.10.1.part2.rar.html
    http://hotfile.com/dl/86887725/c9650d5/IAR_EW_ARM_6.10.1.part3.rar.html
    http://hotfile.com/dl/86887761/0c09d7a/IAR_EW_ARM_6.10.1.part4.rar.html
    http://hotfile.com/dl/86887860/7a3633a/IAR_EW_ARM_6.10.1.part5.rar.html
    http://hotfile.com/dl/86887927/8822083/IAR_EW_ARM_6.10.1.part6.rar.html
    http://www.fileserve.com/file/BXPDRJT
    http://www.fileserve.com/file/sYr2gZs
    http://www.fileserve.com/file/Fncc2wU
    http://www.fileserve.com/file/BwtEpDz
    http://www.fileserve.com/file/7J8H2C9
    http://www.fileserve.com/file/MSxU24E
    http://uploading.com/files/412fd9b2/IAR_EW_ARM_6.10.1.part1.rar
    http://uploading.com/files/7caad377/IAR_EW_ARM_6.10.1.part2.rar
    http://uploading.com/files/f221cce6/IAR_EW_ARM_6.10.1.part3.rar
    http://uploading.com/files/86b9d47m/IAR_EW_ARM_6.10.1.part4.rar
    http://uploading.com/files/32a6cm9d/IAR_EW_ARM_6.10.1.part5.rar
    http://uploading.com/files/f344bce6/IAR_EW_ARM_6.10.1.part6.rar
    http://uploadstore.net/1cs2396nywml/IAR_EW_ARM_6.10.1.part1.rar.html
    http://uploadstore.net/h0vucwosy6rs/IAR_EW_ARM_6.10.1.part2.rar.html
    http://uploadstore.net/2cllb4wkzqv4/IAR_EW_ARM_6.10.1.part3.rar.html
    http://uploadstore.net/4hs6s02clnrs/IAR_EW_ARM_6.10.1.part4.rar.html
    http://uploadstore.net/mpws359g3qim/IAR_EW_ARM_6.10.1.part5.rar.html
    http://uploadstore.net/gxqjfhs8vqhd/IAR_EW_ARM_6.10.1.part6.rar.html
    http://www.filesonic.com/file/38594577/IAR_EW_ARM_6.10.1.part1.rar
    http://www.filesonic.com/file/38594583/IAR_EW_ARM_6.10.1.part2.rar
    http://www.filesonic.com/file/38594641/IAR_EW_ARM_6.10.1.part3.rar
    http://www.filesonic.com/file/38594639/IAR_EW_ARM_6.10.1.part4.rar
    http://www.filesonic.com/file/38594863/IAR_EW_ARM_6.10.1.part5.rar
    http://www.filesonic.com/file/38594645/IAR_EW_ARM_6.10.1.part6.rar
    http://www.zohall.com/forum
    پاسخ : IAR Embedded Workbench for ARM v6.10.1
    یک سوال :
    کسی تونسته POWER PACK سری جدید مخصوصا GUI رو گیر بیاره؟
    بگذارعشق خاصیت تو باشد نه رابطه خاص تو باکسی
    موفقیت پیش رفتن است نه به نقطه ی پایان رسیدن
    نلسون ماندلا
      لینک دانلود همین نسخه در رپید باز در دو فایل زیپ 250 مگابایتی :
      http://aristar.dl.rapidbaz.com/zoZH/...2180.part2.rar
      http://aristar.dl.rapidbaz.com/zoZn/...2180.part1.rar
      در مورد سلامت کارکردش هم بهتون یقین می دم چون خودم دارم ازش استفاده می کنم .
      موفق باشید!!! :job:
      Aristar Group - Always And Forever
        نوشته اصلی توسط رضا بابایی
        یک سوال :
        من یک نسخه گرفتم ولی باهاش مچ نبود و هنوز تو هیچ سایتی من پیدا نکردم . اگه پیدا کردی ما رو بی خبر نذار!!
          این ورژن هیچ جوری برا من کرک نمیشه
          من ورژن 5.4 را راحت کرک کردم و استفاده می کنم ولی این ورژن اعصاب برا من نگداشته
          مگه روش کرک کردن این فرق داره؟
          چه جوریه؟
          { خلاف قوانین - پاک شد }
            دوست عزیز نحوه کرک کردن این نسخه با نسخه های قبلی هیچ فرقی نداره و من همین الآن بصورت کرک شده دارم ازش استفاده می کنم
            در ضمن یه سوال شما اون نسخه ای که من برای دانلود گذاشتم را دانلود کردید یا مال دوستمون رو؟
            پیروز و سربلند باشید!!!
              من از سایت techno-electronic دانلود کردم
              نمی دونم به خدا چرا اینجوری 4 5 بار پاک کردم دوباره نصب کردم
              عجیبه
              ورژن قبلی که دارم 5.4 خیلی سریعه ولی این یه مدت برا کامپایل وقت میبره آخرشم خطای لایسنس میده
                من فایل هایی که در بال گذاشته بودید هم دانلود کردم
                میشه نحوه کرک کردن و فایل هایی که با آن کرک کردید رو بگذارید؟
                  عین نسخه های قبلی فقط کافیه تو پوشه کرک فایله !RUNME رو اجرا بکنید و از اونجا بر اساس نسخه تون که همون ARM هستش سریالش رو وردارین .
                  من فایلهای کرک رو دوباره توی سایت دیگه براتون پلود کردم . شما می تونین استفاده کنین
                  http://hotfile.com/dl/100381333/7128772/Crack.rar.html
                  موفق باشید. :job:
                    من این فایل رو که باز میکنم خطا میده
                    دستی تغییرش میدم
                    من از ویندوز سون 64 بیتی استفاده میکنم
                    احساس می کنم مشکلم برا اینه!
                    بازم سعی می کنم
                      مشکل رو فهمیدم!
                      باید دسترسی administrator بهش می دادم
                      همیشه خودم اینو به همه می گم و الان یادم نبود :دی
                      برای ویندوز سون و ویستا
